SOURCE: How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
SOURCE: Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
SOURCE: Music is coming through my sub as well as bass
your amp might have a low pass filter and a high pass filter make sure it is switched to low pass and that should prevent music from coming out of the subs and just alow the bass too
SOURCE: Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
