Sewing Machines Logo
Shelia Cabrero Posted on Jun 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my machine. I have Singer 7285q Patchwork. I got a E7 code, and now my machine will not do anything but beep. Help!
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Jul 07, 2017
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2616576
Points
59176
Search for:
Make Model error E7
sometimes the owner's manual shows error codes in the troubleshooting section.
5 Related Answers
Anonymous
  • 110 Answers
  • Posted on Jan 08, 2008
SOURCE: Singer 744 beeps
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Anonymous
  • 108 Answers
  • Posted on Feb 15, 2010
SOURCE: Need owner's manual for Bernina Patchwork 140
try at www.ifixmachines.com
Anonymous
  • Posted on May 24, 2010
SOURCE: The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on May 18, 2012
SOURCE: My Singer Brilliance 6180 flashes E7 there is nothing about it in the manual
try changing the needle
try using a different bobbin
if these suggestions don't help then I suggest you take the machine to be checked
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Sep 28, 2016
SOURCE: How do I get my Singer S800 work when there is an E7 message
Give this a try:
How do reset an E7 error message Singer Stylist 7258 Electric Sewing...
have an error message ShopYourWay
I got a C4 code and my machine won’t work now. I checked for threads and cleaned the machine but it is still happening. What should I do? I have the singer patchwork 7285q.
First check the bobbin winder is fully positioned to the left. Move it to the right and back left.
Will it wind a bobbin?
Can you bring bottom thread to top with handwheel?
Is this a new (to you) machine or one you've had and well used?
Cleaned?... if you didn't remove the needle cover and remove the bobbin case to clean race area then that may need to be done. Plenty of videos of similar machines on how to.
Comment below for further assistance.
E4 code on singer 7285Q machine
Search for:
Make Model E4 error code
1helpful
Is it possible to install a knee lift on a singer patchwork sewing machine model 7285q?
Machines with the kneelift option come from the factory with that option. To try to add it to your machine may be extraordinarily expensive.
Error message E4 when turned on. Is there anything i can do to fix?
Consult the Troubleshooting section in the owner's manual. Frequently there is information about the Error Codes and how to resolve them.
Thread not picking up
try a different needle--one for the fabric being sewed
rethread the machine--top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
there could also be a timing problem, if the problem persists, it would be a good idea to have the machine checked
Why can't I thread with automatic thread feeder
the automatic thread feeder may need some type of adjustment, so if the problem persists, you might need to have the machine checked
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
