Posted on Jul 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dirty printing - Minolta EP1030/1030F CS/PRO Copier
Adorjani Laszlo
Level 3:
  • Minolta Master 1,316 Answers
  • Posted on Jul 31, 2009
Adorjani Laszlo
Minolta Master
Level 3:
Answers
1316
Questions
Helped
456921
Points
2563
Is Minolta EP 1030?If yes,clean the mirrors,lens,lamps.
Anonymous
Level 3:
  • Master 952 Answers
  • Posted on Jul 26, 2009
Anonymous
Master
Level 3:
Answers
952
Questions
Helped
198430
Points
2713
Thanks for using Fixya!
If your printer is printing bad quality prints, You'd better use the printer cleaning software that came with your system. Most of the time, this software is installed to your operating system. So, just do the normal way of cleaning your printer head but do it like 5-10 times.
Have a wonderful day.
- HotRatchet
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
Printing dirty
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. Your printer may be printing fuzzy, blurry, or other faint text because of dirty print heads, so try to clean them, including roller.
I have a HP Laserjet 4250 that is printing dirty prints. I have replaced the toner and the fuser unit and cannot correct the problem. I have 2 of these printers and the toner and fuser unit works no...
Try printing from the manual feed tray(tray 1). Put a few sheets of paper in the tray. Print anything that is more than two or three sheets of paper. The paper path test is good, 10 sheets. As the paper gets about halfway into the printer, open the top door. Pull out the toner cartridge. Look down at the paper. If it's dirty it has to be the toner or the transfer roller. If it's clean it could be a dirty paper path or fuser.
Vacuum out the printer, if you have mounds of toner laying in the paper path, everything that comes out of the printer will be dirty.
5helpful
Why do my prints have a purple tint to them?
Most cauuses to this is dirty or failing print head.
Many people would say it was the sponge that is doing that but let me tell you if it was a full sponge you would not even see that color tint. Its the print head that is not mixing correctly due to being dirty or corrosive. Do you use refilled ink cartridges? If so you answer is iron clad your print head will need to be replaced and you need to put a stop to the refilled oslution, if not then the print head got dirty or is defective.
1. print head cleaner
2. new print head.
thanks hope this does help please do be considerate and rate and leave feedback for your free answer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
1helpful
2answers
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
2answers
Dirty Copies
clean the ink box from printer where the cartidge park
2answers
Canon Laser Class 720i
The drum is n/g or the optics are dirty. possible print roller.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
