Question about Whirlpool MH1170XS Microwave Oven
My Whirlpool MH6700XW over stove microwave stopped working and light does not come on. Clock, key pad, timer, stove lights etc. are all OK. It just doesn't cook. Roger
    Problem Solver:
  • 18 Answers
Could be a bad mag, cap, diode,trans.
Posted on Jul 28, 2009
SOURCE:
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Microwave doesn't register it being closed, doesn't work,any ideas?
I have the same problem...manufactured July of 2005. xms -2 Clock works, key pad works, doesn't register door as being shut so it leaves the light on and won't accept a start command.
Feb 05, 2011 | Whirlpool MH1150XM Convection/Microwave...
How to set the clock on my sharp carousel microwave
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Sep 25, 2009 | Sharp Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Jan 01, 2009 | Microwave Ovens
Mircowave blew
inside check transformer and heating element
Feb 27, 2018 | Amana ACO1840A Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
543 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
