SOURCE: ALl of the buttons on the outside are jammed...
press and hold both the water and ice button together to reset
SOURCE: Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
SOURCE: My refrigerator is 60 degrees and my freezer is hovering around 25 degrees
Seems to me that your defrosting timer is not working.When defrosting is not working unit will collect ice on element(Hidden)Could also be fan inside refrigerator which is not working properly.You need a repairman.Jan
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
SOURCE: My digital display reads 88 degrees for the fridge
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
