Question about AT&T Cell Phones
I have a Pantech 9060 imei: 012**********80 with at&t that is patterned locked and I also don't have the google account information. factory reset doesnt work.
SOURCE:
  • 4 Answers
SOURCE: i cant unlock my sony
try password as "null"
Posted on Oct 14, 2010
cyberprem
  • 166 Answers
SOURCE: mobile locked with pattern lock
Try to replace your stock rom with new one using odin.
Posted on Nov 28, 2012
sourcecode20
  • 93 Answers
SOURCE: my phone is locked, saying
Best Solution;
1. Power off phone
2. Press and hold Home Button ( middle ) + Volume Up + power on button
3. Wait for 5 second until Android System Recovery menu appear
4. There are 4 options
reboot system now
apply update from sdcar
wipe data/factory reset
wipe cache partition
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
Posted on Jan 20, 2013
SOURCE: T mobile prism locked to many pattern attemps. How can I fix? Dnt remember password for google account. Tried resetting my password on my pc still did not work. HELP PLEASE?
HI SIR ,I VE T MOBIL PRISM
TOOMANY PATTEREN ATTEMPTS ' SO I WANT TO UNLOCK WITH OUT ERASING DATA CAN U HELP ME PLZ
Posted on Jun 29, 2013
SOURCE: Micromax A27 Google Account & Pattern Unlock done
A 27 TOO MANY PATTERN SOLUSION
Posted on Jul 09, 2013
Pantech FccCE0700 cellphone Model No. TXT8045VW, IMEI No. 356802-04-1550939 how to unlock this phone?
Hi Dhimant, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. BUT if you want to factory reset then the link below is a short youtube video on how to rest the pattern code on your phone, The
guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. I hope this helps...... CHEERS..
EASY WAYS How To Unlock Android Passwords
Apr 14, 2016 | Pantech Cell Phones
My phone is locked with pattern,an i for got the pattern. what do i do
If you are unable to unlock it, you can try to use the Google account to unlock it, if unable to do so, you'll need to perform a factory reset on the device. However, performing a factory reset will erase all the information on the device including the contacts, messages and all the downloaded apps.
Dec 27, 2015 | KYOCERA CORPORATION Android Apps
I have an lg optimus straight talk phone. I had too many pattern attempts and don't know the email and password to unlock it. Tried a hard reset with the volume, home, and power button, but it didn't work....
Hard reset LG Optimus V VM670 full reset
WARNING: All of your data will be lost!
1. Turn the power off.
2. Press and hold the following keys for over 5 seconds: VOLUME DOWN key mxiqtgowitk7gwzqbxyhdcltfs16ozyouevveokanftkdtnwwymj9scskqm0ieh5eq5ckaujhqmaoieaoif3fpipvbh8k+pbkkoaaaaasuvork5cyii= + HOME opgbfz5a5gqhftj+tmuaaaaaelftksuqmcc + POWER/LOCK bfcjfp4fns6dfvyu0xyaaaaasuvork5cyii=.
3. When the power turns on, release these keys.
Settings > Privacy > Personal data >Factory Data Reset
If you've entered the wrong information 5 times, you will need to wait 30
seconds before you can attempt again.
When you can't recall your unlock Pattern, PIN or Password:
If you've set up a Google account on the device, tap the Forgot pattern? button. You will be able to unlock the device with your Google account user
name and password.
If you haven't created a Google account on the device, you will need to perform a factory reset.
(CAUTION! If you perform a factory reset, all user applications and user data will be deleted. Please remember to back up any
important data before performing a factory reset.)
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
May 30, 2014 | Cell Phones
HOW TO UNLOCK A PANTECH PHONE WITH TO MANY PATTERN ATTEMS
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. go to recovery (vol down + search +power) and do a factory reset/wipe (it will erase all your files)
Feb 18, 2014 | Pantech Great At&t P9070 Burst Smartphone
Forgot my password and phone screen locked.
you can use Google account to recover it OR secondly you can factory reset phone.
Reset Lock Pattern Step 1 Power on the Infuse and enter any incorrect lock pattern. The message "Sorry, try again" displays. Step 2
Tap "OK" at the prompt, and then enter the incorrect pattern four more times. Step 3
Tap the "Forgot Pattern?" button. Enter your Google Account information, and then tap "Sign In." Step 4
Enter your new lock pattern, and then touch "Continue." Alternatively, tap "Cancel" to enter a new pattern later.
Factory Reset Step 1 Power off your Samsung Infuse. If it does not turn off, take out the battery and reinsert it. Step 2
Press and hold "Power," "Volume Down" and "Volume Up" together. Step 3
Let go of all the buttons when the Android logo appears. Step 4
Press "Volume Down" to highlight "Delete All User Data," and then press "Power" to select the option. Step 5
Press "Volume Down" to select "Reboot System Now," and then press "Power" to reset the Infuse to its default state.
Dec 18, 2013 | Samsung Cell Phones
Karbonn mobile full reset codes
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 29, 2012 | Cell Phones
My phone is locked, saying enter google account info but nothing works, also cant remember pattern either
Best Solution;
1. Power off phone
reboot system now
Sep 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
I forget my screen pattern code how can unlock the screen pattern code with out re setting LG optimus 500 if it does not work . can I do factory reset and how thank u
You can unlock LG p500 screen pattern using your google acount, but if you already set it in your phone. To unlock lg phone with google account you just need to type any wrong pattern 5 times then your phone will be asking your google account and after you insert that google account you can setup new screen patern for your phone. Unfortunately if you don't ever setup google account in your phone, you only can unlock it with factory reset methods. For the details about this process you can see at here at page 21 and soon. I hope my solution can solve your problem.
Sep 13, 2011 | LG P500 Cell Phone
My samsung galaxy ace is pattern locked & i cant open my phone . i forgot my gmail account also
My samsung galaxy ace2 18160 is pattern locked & i cant open my phone . i forgot my gmail account how to open my phone
Mar 11, 2011 | Samsung Cell Phones
Pantech c150 phone locked up. How can I reset?
Search Results
PANTECH C150 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/pantech/pantech-c150/ Hard Reset PANTECH C150. Switch on the cell phone. Hard Reset PANTECH C150. Press this in sequence: *01763*737381#; Wait until your phone restarts. That's all. If this was useful, please share to help others and follow us on Facebook, Twitter and Google+. WARNING ! Hard Reset will erase all of your data
PANTECH C150 - Frequently Asked Questions ... - HardReset.info
www.hardreset.info/.../pantech/pantech-c150/.../reasons-why-you-might-need-to-hard... Hard Reset in C150 Will help to: PANTECH C150 runs too slowly; Reset and disable forgotten screen lock password or pattern; Might resolve hang-ups & freezing problems; Might resolve unexpected Application crashes; Wipes personal data phone before you sell your phone or after you buy one; Regain default ...
Hard Reset PANTECH C150 - IMEI.info
www.imei.info/hard-reset-3111-pantech-c150/ Hard Reset PANTECH C150. Are your looking for a way to make your PANTECH C150 work faster? Do you wish to clear all of the data on your PANTECH C150 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data ...
pantech c150 hard reset Google Search
Dec 11, 2017 | Pantech C150 Cellular Phone
Cell Phones Logo
Top AT&T Cell Phones Experts
Vincent G
Vincent G
Trimesh
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
