Bought my Acurite Weather Station Model 00503/00509 brand new and have not been able to get it to read the outside temperature. Everything else works except the outside temp.
My National Geographic Weather Station is the opposite. The outside sensor only indicates the temperature, but the single CR2023 battery lasts a year. The inside unit on my desk lasts around 5 - 6 months and lets me know if needs a battery by showing the outside temperature as ' -- '
Although the manual says 'rechargeable batteries are not recommended', I would try 4 Sanyo Eneloop batteries. Or you could contact Acurite Support and ask them if your battery use is excessive?
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
