SOURCE: rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
SOURCE: I need a english manual for a Toshiba RCK B5X rice cooker
you should have a lever you push down to cook and it comes up when the rice is done,,
SOURCE: I accidentally put the rice into the outer pot
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
SOURCE: need manual for Aroma rice cooker and steamer
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: My oster 3071 rice cooker ''E2'' error
it happened on my oster 3071 the error e2 just appear the only that i did was open it and I found out that the blue wire which is connected on the lid is cut so i just reconnect the wire and stick it together using souldering iron and presto it is good as new again
