Sewing Machines Logo
Celia Yarde Posted on Jun 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Necchi model 931 is not doing any zig zag stitches nor decorative stitches only straight stitiches
R.A. Ellis
Level 3:
  • Necchi Master 12,731 Answers
  • Posted on Jun 25, 2017
R.A. Ellis
Necchi Master
Level 3:
Answers
12731
Questions
Helped
2615338
Points
59176
A mechanical machine? How long since it's been thoroughly cleaned and oiled? Sounds like the machine is seizing due to old oil that has dried.
Wheel on right side that controls the needle up and down is very tight...
2answers
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
What is the difference in Necchi BF and Necchi BU?
Necchi BF is a straight stitch machine
Necchi BU is zig zag machine
Necchi BU Supernova had cams for additional stitches
Necchi 4825, cannot get machine to sew the different stitches - have tried adjusting width/length just all come out as some form of zig zag - arggh!
Since your machine is brand new, it is under warranty. Take it back to the dealer you purchased it from and have them repair it. If you try any repairs yourself, or by a 3rd party, that will probably void your warranty.
I bought a R-2000 never used Necchi at an estate sale. Did not thoroughly read the manual before beginning to sew. Now it will only sew a zig-zag--think I did not use the release knob before changi
since you bought the machine at a state sale it would probably be a good idea to have the machine serviced.
you should be able to go from straight stitch to zig zag with out any problems.
if you move the dials or knob & the machine will not do a straight stitch then it needs to be checked
Fix zig zag
are you using a interfacing or stablizer with the fabric?
try replacing the needle
possible the zig zag gear is worn or damaged & needs to be repaired
1helpful
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
1helpful
Casn I use a double needle on this model?
If you have a zig-zag stitch on your machine, you have the capability of using a twin needle when using a STRAIGHT stitch. The width between the needles is the same as the width for the z-z stitch but you won't be using that stitch. Only the straight stitch.
Need a straight stitich How to make the machine do a straight stich...not reponding to settings
not sure which model you have but you should have a stitch length control and a stitch width control. locate the stitch width control and set it to zero.
if you have done this and the machine continues to zig zag the zig zag mechanism inside the machine is most likely seized up. try lubricating all linkages inside and move the control lever a few times to see if it will free up.
if not you may need a tech to service the machine.
scott.
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
