F4 is a temp sensor error. you can find more info here
https://appliancerepairinfo.com/lg-oven-error-codes
SOURCE: F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
SOURCE: f4 error code
Ok, test the element for its operational value. if the element is not getting a signal to warm from the control board, this will be the issue, considering that the element is new and able to warm. replace the Oven control in this case.
JUst to be safe, back track the installation to make sure every connection was properly united. make sure the element was installed correctly. if so, replace the control.
SOURCE: Whirpool Oven Model # rb260fxyq f4 error code
Oven temperature sensor (RTD) shorted
Replace Oven temperature sensor (RTD)
SOURCE: F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Testimonial: "Thanks for the info. It was extremely helpful."
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
