SOURCE: number of rings
In your voicemail system programming menu set the time period before which the voicemail clicks in. Usually 10 or 15 seconds.
SOURCE: Rings before KX-T7736 goes to voicemail
This is just the quick answer and may not be exact. System program 203 is the intercept time. It's probably set by default to 40 seconds. A ring cycle is about 6 seconds. Try adjusting that down to, say, 20 seconds and see if that works. I have your exact setup in my office, but I'm not in my office for the rest of today. I may get a chance to play with the timing on Saturday.
Carl
SOURCE: # of rings before voicemail picks up
Yes there is, but you have to know multiplication :-)
At the extension, from the intercom dial *713 and the 2-digit time in seconds. An internal ring cycle is about 6 seconds. I think the default time comes from the system and it may be 40 seconds.
Carl
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
