Cell Phones Logo
Harricka Danise Posted on Jun 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Galaxy s7 edge
Saying no service
honeybun1986
Level 3:
Master:
  • Master 329 Answers
  • Posted on Jun 22, 2017
honeybun1986
Master
Level 3:
Master:
Answers
329
Questions
Helped
64211
Points
1069
Check with your sim card first whether it's working or not. If it is working, Try a factory reset.
If that doesn't work either,dial the following code and see whether you gets your 15 digit IMEI ( Don't post it here. Just see whether it is coming)
CODE : *#06#
If you see only a bunch of "0"s or just a "0" or an empty space, you'll need to restore your IMEI
If it is not the case, it should be a hardware fault.
3helpful
2answers
What is Sim Network Unlock Pin of At&t Samsung Galaxy S7 edge? AT&T Galaxy S7 edge G935A
At&T Samsung Galaxy S7 edge sim network unlock pin is 8-16 digits code which is unique for every phone depends upon your G935A imei. When you have it once, Just enter it & do Unlock Samsung galaxy S7 edge G935A Network instantly. I recommend you 24x7Unlockcodes.com to unlock it`s network the best Samsung sim network unlock codes provider
tip
How to hard reset your samsung s7 or s7 edge
How to hard reset Galaxy S7 and S7 edge
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
  • Open the Settings app.
  • Choose Backup & Restore > Factory Data Reset.
  • Now select Reset Device > Erase Everything.
  • Confirm the warnings and wait for the process to finish.
  • Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
  • Power off your device.
  • Wait for a few seconds while your phone is shutting down.
  • Press and hold the Power, Volume Up and Home buttons simultaneously to get into Recovery mode. (read: how to get into Galaxy S7 or S7 edge recovery mode)
  • Use Volume keys to navigate and Power button to select an option in Recovery mode.
  • Once in, from the main menu, using Power key, select wipe data factory reset.
  • If you want to clear app data cache too, choose wipe cache partition. Clearing cache often fixes various software related issues.
  • When done, go back to main recovery menu.
  • Select reboot system now and that's about it.
Hope the above tips help you fix Galaxy S7 issues and bugs.
on Jan 16, 2017 • Cell Phones
Bypass Google on Galaxy S7 without pc,wifi, tools or sim card
SAMSUNG Galaxy S7, S7 edge FRP/Google Lock Bypass - No ...
https://www.youtube.com/watch?v=k73dQOXPAJU
29 Mar 2019 ... Hey guys! This is my new video for SAMSUNG Galaxy S7, S7 edge FRP/Google Lock Bypass - No HushSMS, No Talkback, No add Call - New
2answers
I forgot the unlock pattern for my samsung galaxy s7 edge
If you forget the pattern lock then you have to hard reset your samsung galaxy s7 edgi. This rese will wipe all your data in the phone & remove it`s pattern lock.To do this please follow the steps below:
  1. Ensure the device is powered off.
  2. Press and hold the Volume Up and Home buttons.
  3. While continuing to hold volume up and home, press and hold the Power button until RECOVERY BOOTING appears in the upper-left then release all buttons.
  4. From the Android Recovery screen, select Wipe data/factory reset.
    Utilize the volume buttons to cycle through the available options and the power button to select.
  5. Select Yes.
    Allow several seconds for the factory data reset to complete.
  6. Select Reboot system now.
    Allow several minutes for the reboot process to complete.
    If applicable, set up your device.
24x7unlockcodes.com is the right place to unlock your Samsung Galaxy S7 Edge. You may need this when you are switching your sim card for change your network or visiting abroad. You can get your unlocked permanently by our hassle-free procedure in a competitive price online at your door step!!! Just order us & relax at your home, we e-mailed you once it done.
Use of unlock code for Samsung Galaxy S7 Edge network unlocking is totally legal. We insured you that our service will not change any feature or behavior of your Samsung Galaxy S7 Edge. The data in your Samsung Galaxy S7 Edge will also remain protected.
Under circumstances like, If the code will not successfully derived by us or will not work on your Device, we guarantee our customer fully refund of their money.
For Permanent Samsung Galaxy S7 Edge Network Unlocking
https://24x7unlockcodes.com/product/att-samsung-galaxy-s7-edge-unlock-code
For Permanent LG Sim Network Unlock PIN
https://24x7unlockcodes.com/brand/lg
For Permanent Samsung IMEI Unlock Code
https://24x7unlockcodes.com/brand/samsung
Best Sim Network Unlock Pin Provider
24x7UnlockCode Network Unlock Code IMEI Unlock Code Unlock Code
2009 Lucerne is blowing the ECM 10 amp fuse. Seems to do it after a right turn and acceleration. The circuit has ben traced but no issue was found. Said it could be a short that is hard to find.
  • GALAXY S7 EDGE CASE: Combination of clear hard back panel + soft flexible edges = excellent protection showcasing your Galaxy S7 Edge. Compatible only with Galaxy S7 Edge.
  • BEST PROTECTION: The lips on both front and back protect the screen and the back panel from scratches
  • SCRATCH RESISTANT BACK COVER: Premium Japanese polycarbonate with scratch-resistant coating will keep your help your case endure scratches and scuff marks more than a regular case. Longer life and cleaner look for your case and for your Galaxy S7
  • IMPROVED GRIP: Flexible rubber edges of this clear case for Galaxy S7 Edge hugs each and every corner of your Samsung Galaxy S7 Edge and allows you to get a better grip
  • German TPU rubber bumper edges and Japanese polycarbonate back cover are infused using the latest technology.
AmanStino Galaxy S7 Edge Case Hybrid Scratch Resistant Back Cover with...
1helpful
3answers
How to root samsung galaxy S7 SM-G930FD
Samsung Galaxy S7 and S7 Edge are the popular ones of the latest Samsung smart phones. Although the new duo is armed with the latest technology, many S7 or S7 Edge users still want to use the devices as their own likes. Rooting is just to fit their needs. Rooting S7 or S7 Edge allows users to give more functions to their devices. It means that users will have access to their Samsung. Here this tutorial will show you how to root Samsung Galaxy S7 or S7 Edge and undelete files from them.
http://samsung-deleted-data-recovery.blogspot.com/2016/11/how-to-root-samsung-galaxy-s7-and.html
Samsung bdp1600 blu-ray player connectivity
No, I was looking for free technical advice.
Top Galaxy Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
