Tablets & eReaders Logo
Renesmae White Posted on Jun 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lg tablet is on the charger and says its charging but every couple of seconds it stops charging while on the charger. My battery percentage has been at 18% for almost four hours.
Susan Cao
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 108 Answers
  • Posted on Oct 04, 2017
 Susan Cao
Expert
Level 2:
New Friend:
Cheetah:
Answers
108
Questions
0
Helped
24689
Points
242
It is possible that the battery in the tablet has gone bad, but it is MUCH more likely that you have a bad charging cable. Try charging another device with the questionable cable and see if the problem continues or buy a new cable and see if that solves the problem.
5 Related Answers
Anonymous
  • 1187 Answers
  • Posted on Sep 03, 2009
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Anonymous
  • Posted on Aug 20, 2012
SOURCE: charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
Anonymous
  • 84 Answers
  • Posted on Nov 28, 2012
SOURCE: I purchased a nexus 7 tablet yesterday and I want to now if it is bad for the battery to keep it on the charger after it is fully charged?
The owner's manual that came with it should have the answer to your question.
Anonymous
  • Posted on Feb 20, 2013
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Anonymous
  • 6 Answers
  • Posted on Apr 02, 2013
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
1helpful
My tablet is charging backwards. What should I do?
Optimus dying on charger/charging backwards - Android Forums at ...
forums.androidcentral.com > ... > LG Optimus Series > LG Optimus S
Aug 2, 2012 - 11 posts - ‎8 authors
Lately my Opti s hasn't been charging correctly sometimes it won't charge I tried different chargers and i use three batteries two that are brand ... LG G2: Battery and Charging problem- super annoying.
Apr 27, 2014
Samsung Galaxy S3 charging issue - Page 6
Aug 23, 2013
Galaxy S4 won't charge - Page 5
Jul 2, 2013
Says its charging but it isn't?
Feb 5, 2012
More results from forums.androidcentral.com
Why does my battery percent go down when plugged into ...
I cant get the device to charge
If you don't have the original charger and cable, it won't ever say, "charging", but any standard USB cord plugged into any standard USB charger will work. It just doesn't say, "charging", and will charge slowly. Check the percentage of battery, and check again in half an hour. You will see that it is indeed charging.
I took mine to a B&N store, and that's what they said. They no longer stock the chargers/cords.
How to get my battery to charge. plugged it into charger and will not charge. had it on the charger all night and still at same percentage
Check the charger and cable if they are not originally coming with the unit itself.
If they are aftermarket, check if they both on their own can support 2A charging current. For the adapter, its rated ampage should be on the label by ampere. For the cable itself, it must be a SAMSUNG tablet compatible one.
4answers
Battery will charge to 100% only 50%
Morning Emily,
A couple of questions, then a couple of ideas.
  1. Are you using the charger that came with the tablet or are you using a universal charger?
  2. Do you leave the tablet on the charger a lot of the time or do you only charge it when it gets very low on charge?
Often devices like these need to be drained periodically so that your battery does not develop a shallow cycle. Shallow cycle can often occur whenever a device is charged often before it actually gets down to a low percentage of this battery capacity. If you have been typically keeping it charged without letting it drain I would suggest leaving it on and letting it drain fully and then try to recharge again.
If you have not been doing constant charges as described above, then it sounds to me like either you have a bad charger or there something wrong with the battery in your device. I'm going to provide a link to a Page on the next book site so that you can see some of the information related to your device.
I think the biggest questions to be asked are, a) is the charger that you're using putting out sufficient power to charge the battery properly, or b) is the battery in your unit defective. These questions can probably be best answered through the store which you purchased it, such as a Best Buy or wherever it is that you got it. They should be able to analyze the output of the charger to see if it's correct. If it is correct and again if you've not been doing the shallow cycling then that would indicate a problem with the battery.
I'm including some links below that might be helpful for you. The first one is to a knowledgebase article dealing with battery and battery life. The subsequent links are for the manual and also for the technical specifications for your device. The tech specs will probably help as far as your battery and also what should be the output of your charger.
Knowledge Base:
http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/71/23/battery
Links:
Manual http://www.nextbookusa.com/pdfs/NEXT8P_Manual.pdf
Spec Sheet http://www.nextbookusa.com/pdfs/NEXT8P_Spec_Sheet.pdf
I hope this helps.
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Archos arnova refurbished 7k G3 tablet frozen on ARNOVA screen
i had same problem with my gadget,i replaced the battery.and have it checked to make sure no reformattingg needed
How do I know if it is charging? I think it is not.
When you plug into it , it should show a small battery with percentage of charge on the screen , is there power at the wall outlet u have charger plug in at ????
Tablet won't charge
With your tablet unplugged, press and hold the Power button for around 30 seconds. Then place your tablet on the charger (preferably the home charger) and wait a couple minutes. Then press and hold the power button for around 30 seconds again. If this does not help, then the battery may be bad. Storing a lithium-ion battery should done with no less than 40% battery life left, otherwise the battery voltage or power can go below the safety net (li-ion batteries are not fully dead when your device tells you they are. Once the battery reaches below the safe level, the battery is no longer good or safe to use anymore).
Top LG Tablets & eReaders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
