2006 Mitsubishi WD-73732 TV. I replaced the bulb, which I have done before. It won't come on. The timer light flashes about 30 seconds to a minute then the lamp light starts blinking yellow.
Common Repairs For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Hi, Is it Mitsubishi WD-52628 TV? please confirm model number. Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem? Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed. Thanks.
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
