Razor E100 Electric Scooter Logo
John Pike Posted on Jun 17, 2017
Need manual for boreem jia series model n/b 203_be 84
How do you get access to the batteries on a Boreem Jia electric scooter.
Know this is an old post but if someone else needs to know how to get to the batteries on boreem jia remove the nuts at the bottom of the shaft holding the seat where it connects to the fiber glass frame and then remove seat and shaft and then four nuts "2 on each side" under the feet rest, you may need locate the tops under the boreem label by peeling it back to hold while untighting that's it, now you can slide the housing to the side be careful of your wiring only enough room to access and remove batteries. You will have to either cut or use soldering gun to free up the wires hope it helps
Can I charge my boreem jia battery by jump start charging from my car battery?
If the battery is 12 volts and has a high amps(50+) out put , yes. If it is milliamps, no.
What color wires connect toggle to ignition on boreen jia electric scotters?
black is negative, red is positive to controller, yellow is ignition on
Boreem Jia series Instructions onhow to replace the battery
unhook positive cable then the negitive cable, pull out, then put new one in. hook the negitive cable up first then the positive cable.
Jan 09, 2013 • ATVs
6helpful
2answers
Boreem Jia Scotter - Model ID and manual?
how do i change the battery on my boreem jia series electric scooter
Aug 23, 2009 • Cycling
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
