Health & Beauty Logo
Betty Beatty Posted on Jun 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having a lighted wrench come on when I'm riding my jazzy elite he chair. Not sure why. Except portions of chair move slowly and makes a small grinding sound. Thank you.
Lawrence Oravetz
Level 3:
  • Elite Master 10,558 Answers
  • Posted on Jun 17, 2017
Lawrence Oravetz
Elite Master
Level 3:
Answers
10558
Questions
Helped
2700023
Points
29284
The problem you have with the chair moving slowly and the grinding sound is the reason the light is coming on. It needs to be serviced soon before the cost of repairs gets larger.
I have a Pride Jazzy Elite. When I plug into the charger both the power light and the charge light turn green. Any help?
Question edited for clarity and to add the maker.
Question moved to the correct category.
Green lights normally mean your charger is working and the battery is fully charged Leasa.
There are three flavours of Jazzy Elite, this is the manual for one of them. not very helpful on the green lights though.
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_jazzy_elite_es_(elite_gen_2)_om.pdf
This is for the HD & 14 model. Same text
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_elite_series_hd_and_14_om.pdf
Some videos.
https://www.google.com/search?q=pride+jazzy+elite+charging
Jazzy elite hd wrench light flashing two times and chair stops working. says battery fault but i tested the batteries and they are in good shape. only four months old. any ideas would be greatly...
Did you test the batteries under a load, makes a big difference. Batteries can show correct volts however if it has a weak or bad cell it will deplete too rapidly to run the required votes for the motor
Pride jazzy elite he power chair. I can't figure out how to put it in drive. It'll go in neutral. But when I switch the levers to r the lights just run a sequence on joystick then cuts off.
make sure the charger is disconnected from the chair. turn the power on, then push the horn button twice in row, within ten seconds of starting the Joystick. This will reset the lockout. Push on the chair to see if both motors are in the parked position, if one side moves then that side is not locked. both sides need to be locked in order for the chair to run. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
De-sentizie controller on a jazzy elite
Yes, it is possible. If you take the chair to dealer who sells Pride, they should have a programmer available to change the settings on the joystick controller.
Jazzy 600 stops all of a sudden while driving, chair icon and wrench icon on romote appears
Likely 2, 3, 4 or 5 bar flash code. If motors are made by a company like "ELE...." then motor wiring is likely bad inside wire insulation where wires go into motor cap. Rebuild motors and try again. This is a common problem with these motors.
Jazzy 614HD goes into lockout. We can get it out of lockout but goes back into lockout at any movement of the chair........
Make sure any seating system is completely down and in DRIVE position. When chair is unlocked, wait 5 seconds, shut chair off, wait 5 seconds, turn chair back on. Each time you turn the chair on you need to wait 5 seconds for the POST to complete before moving the joystick.
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
1helpful
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Top Elite Health & Beauty Experts
Rob Hill
Rob Hill
jws1013
Paul Carew
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
