SOURCE: Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
SOURCE: hi our thetford cassette toilet (c200)blows the
Probably the rotor has come to a stand still (carbonade). I suggest you will clean the rotor with an house-hold acid liquid (like the one for cleaning coffeemachines).
Flying Dutchman.
SOURCE: I have a thetford toilet in my caravan with
Try tapping on the opening in the bottom of the toilet, the valve that opens, with a broom handle while flushing to see if it has somhow gotten stuck. There is also a micro switch in the groove that the blade turn knob slids into, this could be bad as well as the pump may have been damaged, it is under the toilet roll holder. Here is a link to their repair site.
http://www.thetford-europe.com/web/show/id=51498/langid=42
If this info was useful a vote with the thumbs up would be greatly appreciated.
Testimonial: "I will try your tips out also check out the web site cheers"
SOURCE: i have a thetfold c2 cassette toilet and it has
If the leak is from a compression joint at the water intake to the tank you can tighten it, and it may stop. you will need two spanners. do not over tighten, about 1 cm max turn or it may leak more. hold the nut on the tank side still when you do this. also check to see if the ball inside the tank is shuting off the water, it can be that this needs replaceing, but can be just ajustment of ball float nut is needed.
