SOURCE: j have a moyer diebel
Hello there
The 500HT machine is very old one. Turn off the power first. To get to the elements you have to get the control box off first so you can get to take off the elements cover , now you can see the elements.
If the system have been wired wrong and short circuit it. the temperature control may have to be change too. I would change the two elements and the temperature control and the hi ltd control all together at the same time so you know that system have no problem anymore. All the best Dickson
SOURCE: Moyer diebel 401 ht not reaching temperature ????
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
