I'm having the same issue. Looks like the picture is in 3D mode or something. My nephew can come over push 3 buttons on the TV and it goes back to normal. But when it's off overnight we wake up and it's doing it again. Now my nephew moved to Florida and I have no idea what buttons nor in what order to fix it smh
SOURCE: color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
SOURCE: My Sony Color Rear Video Projector Model # KP-51WS500
I think Jean got this one right. This sounds just like the problem that this site will help you fix.
SOURCE: i just started to have picture problems with my
This model was was made around 1999 and most of the Sony sets use two STK-392-560 OR two of the STK-392-110 CONVERGENCE CHIPS.
The chips are located on two metal heat sinks with fins and usually are on the board on the far left as you look from the back of the TV.
They will be black in color--about 2 and 1/2 inches wide by 1 and 1/2 inches tall and black in color--they will have the STK full number printed on them in white.
A pair of either chips can be bought on Ebay for about 12 dollars plus shipping----there are several fuses that do not look like fuses that protect them--two are on the power board and the rest are around the chips.
What needs to be done here if convergence is bowed and or will not adjust---both chips and any other bad parts--fuses etc need to be located and replaced---usual parts cost is under 30 dollars.
The board will have to be removed from the frame to get at them and they and the fuses are soldered in---you need to be able to solder etc.
If you can do the repair or know a friend who can do it for you -----you can save the set and a lot of money
Most shops are going to get 300 or more for this type of repair.
I know as I have done hundreds of these sets with convergence problems---
I am here to help people---I do this here for free--if you have questions or need advice let me know.
Regards, SD TECH
SOURCE: Picture looks concave. Words, people, everything
You have a convergence malfunction.......the convergence ic's and the protecter picp fuses in the power are will need to be replaced by a qualified perso. A reputable shop may charge around $300 to repair. If you have technical ability,I can guide you further to repair yourself as well
