Windows xp OS intel pro 2200bg wireless driver tho i downloaded a new driver but i dot know what next after installing. thanks
HP compaq old
what makes you think, this laptop sports WIFI direct connect?
wow!
what are you doing name reason, a job a task.?
here ask at HP ,
HP owns COMPAQ, COMPAQ is DEAD now.
but does have very limited support , like here.
why in the world use XP the VIRUS MAGNET. ?
https://h30434.www3.hp.com/
SOURCE: Wireless network connection
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
SOURCE: Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
You dont have WPA2 security in your windows install...
you may wanna check this link
It has instructions in how to enable it without using the ProSET utility from Intel
SOURCE: 10 out of date installed drivers
http://support.acer-euro.com/drivers/downloads.html
THERE ARE ALL YOUR DRIVER'S
SOURCE: Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
