Televison & Video Logo
j
janet taeyoung shin Posted on Jun 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot get my disc to work.my error code is 150-2031
Don A
Level 3:
  • Televison & ... Master 4,491 Answers
  • Posted on Jun 14, 2017
Don A
Level 3:
Answers
4491
Questions
5
Helped
1333406
Points
25816
Error code 150-1031 on the wii u
This error code appears when there is a disc read error.
Either your disc or your disc-reader is damaged. Try cleaning your disc and see if it works. If it doesn't try to insert an other disc to see if the console works.
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
14helpful
3answers
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
1helpful
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
An eror occured whwn burning disc Error code
Not sure if this will help but make sure you do not have two dvd-authoring programs on your computer, this might be causing the error you are seeing. There could be an issue with the media you are burning to, sometimes you have to experiment and find discs that work well with your burner. Burn speed may also be an issue, some discs say that you can burn at 4x speed, when in fact that disc may only be able to accomodate 2x - so try reducing the authoring speed to half the maximum the disc says.
I looked on the GoCyberlink website and was not able to see that error code listed in their support pages. Another possibility though not as likely, you could have a damaged operating system or there is a problem with your dvd burner. Wish I could help more.
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Fix Error code 6 on CD player for 2003 Tiburon GT
From Tiburon owners manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Trying to burn videos to disc
When burning to a disc, at 98% complete it kicks out and screen says it cannot complete task and gives error code FF053005
When burning to a disc, at100% complete it kicks out and screen says it cannot complete task and gives error code FF053005
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
