Model CAT NO 65-865; it turns on to screen that reads, data error, consult owner's manual. can it be repaired? it's over 20 years old, water damage, was working perfectly.
Did you test electrical circuit's before replacing the sensors ? Do you know how they work , where battery voltage comes from ? May only be 5 volt ref. voltage from the transmission control module .
DTC P0720 VEHICLE SPEED SENSOR·A/T (REVOLUTION SENSOR) Revision: May 2004 2003 Sentra TERMINALS AND REFERENCE VALUE MEASURED BETWEEN EACH TERMINAL AND GROUND Diagnostic Procedure ECS005X0 1. CHECK INPUT SIGNAL (WITH CONSULT-II) With CONSULT-II 1. Start engine. 2. Select "TCM INPUT SIGNALS" in "DATA MONITOR" mode for "A/T" with CONSULT-II. 3. Read out the value of "VHCL/S SE·A/T" while driving. Check the value changes according to driving speed. OK or NG OK >> GO TO 3. NG >> GO TO 2. 2. CHECK REVOLUTION SENSOR (WITH CONSULT-II) With CONSULT-II 1. Start engine. - Check harness for short or open between TCM, ECM and revolution sensor. Refer to AT-129, "Wiring Diagram - AT - VSSA/T" . - Check harness for short or open between ignition switch and revolution sensor. OK or NG OK >> GO TO 3. NG >> Repair or replace damaged parts. TERMINAL WIRE COLOR ITEM CONDITION DATA (DC) 10 BR/R POWER SOURCE WHEN TURNING IGNITION SWITCH TO "ON" BATTERY VOLTAGE WHEN TURNING IGNITION SWITCH TO "OFF" 0V 29 W REVOLUTION SENSOR WHEN MOVING AT 20 KM/H (12 MPH). USE CONSULT-II PULSE FREQUENCY MEASURING FUNCTION 150 Hz 42 B/W THROTTLE POSITION SENSOR (GROUND) - 0V
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
I would suggest doing a "Reset". You will loose all your data, but at least you will be able to use it. You do a Reset by removing the bottom case, turning on the BOSS, them pressing the Reset button located inside.
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
