SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: can you get power to a treadmill without the
Hello there. Yes you actually can use a magnet. (thats all the safety key is) It will need to be strong enough to make the switch inside the console activate. I use one from a telescoping magnet used for picking up small screws (available at the big box stores) when I dont have one on service calls.
Just to let you know a refrigerator magnet will not be strong enough!
Good Luck! Tim
SOURCE: NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
