Don't know the model but here are things to check prior to calling your vendor for service:
* Plugged in? No lights? Check if GFRI outlet is tripped out.
* Is it turned on and ready light lit? Some (CWTF's etc.) have a green or read ready lamp that lights up when the brewer is hot and ready to brew.
* No Ready light after 15-20 mins of being plugged in? Check the back of unit for a toggle switch (or rocker switch). Check if it's on. Some units may say "Vacation". It should be on normal or brew.
* Brewing works but not hot. Was the ready light on when you started the brew? You have to wait till it's lit. Still not hot? Then call for service. The heater, High limit, Thermal fuse,Thermostat needs to be checked.
* If this is a new unit then be sure to turn on the thermostat as it comes from the MFR in the off position.
* Final, Call your vendor to be safe.
Aloha, ukeboy57
SOURCE: bunn-o-matio model btx-b does not heat water
Hi, Sounds like a boiler therostat or faulty boiler. Dazza REPAIRER
