Since you didn't specify the model of your Uniden answering machine, I can only direct you to this list. Please select the type of your system and then the model.
Your answer will be attached to your question ... if someone took your question.
In the free section, it is catch as catch can. In the Premimum section, your question stays on top until someone takes it. I would have tried to answer your original question had you asked one ... but alas, you didn't so ... will I can't and it is not likely that I will go looking for it.
its possible that the seals in the wheel cylinder were damaged from the previous problem when it didn`t fix the problem.was the replaced seal a new one or a used one that the someone installed or the seals were defective from the manufacture.also were the brakes shoes cleaned of the brake fluid that was on them from the original cylinder leaking on them as this can cause the brakes to lock up,as well as if the brakes are not adjusted properly can cause this as they will catch and turn with the drum until it can`t rotate any more causing the brakes to lock up.as far as the hardware missing then the person that replaced the wheel cylinder didn`t replace everything that they took off or didn`t know what was suppose to be there as far as parts.
Since you didn't specify the model of your Uniden 5.8GHz answering system, select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl to download a copy of the manual.
YES MY PROBLEM HAS BEEN SOLVED.I CALLED OVERSTOCK WHERE I BOUGHT MY T.V.ON LINE AND GOT AN ANSWER TO MY PROBLEM.
I DIDN"T THINK MY ANSWER WOULD COST &20.00 THATS WHY I DIDN"WAIT FOR AN ANSWER.
THANK YOU HELEN
