SOURCE: I currently have a redjacket well pump 1/2 hp. it
It is aing trouble with it you may have a hole in the plastic pipe or the foot valve is bad. you ca shallow well and has a foot valve on it and if you check both pretty easy. The foot valve will not seat causing it not to give enought pressure and would cause it to run all the time. also the pressure switch may be bad and it is a simple change out costs $35.00 at most hardware store.
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
SOURCE: Shallow Water Jet pump will not start
on the pressure switch are the points closed if not its not asking for water.that flat plat under the two screws with springs on them,push down on the plate that will close the points then figure out why its not closing
Testimonial: "That was exactly the problem, the pressure switch had to be replaced and it now works fine"
SOURCE: hi there my flotec 1/2 hp shallow well jet pump
If it is on the pressure side about the only repair would be to get it welded. If on the suction side you MIGHT be able to "V" it out slightly and use JB Weld or maybe even Bondo... Tose will NOT work on the pressure side however.
SOURCE: my shallow well pump will not pump to 40 lbs
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
