SOURCE: wall mount button LED is flashing, remotes won't
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
SOURCE: I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
SOURCE: amana Ac compressor won't come on. Heat works fine.
would suggest replacing the compressor capacitor first before going any further. The capacitor aids in the initial start up of the compressor and if it is bad the compressor will not start. The capacitor is located in the area behind the control switches and is usually gray in color and round. They may be oval and silver also. For this type unit I think the capacitor is a dual capacitor which means it also runs the fan. Note that the compressor side of the capacitor can be out and the fan still run. So before I would think about replacing the compressor I would replace the capacitor which is about 30 to 40 U.S.D.
Good luck hope this helped
Dave
Testimonial: "great advise god bless"
SOURCE: I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
SOURCE: My Chamberlain Liftmaster Formula 1
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
