There should be a setting on your TV that is called Picture Flip. See if you can access it with your Sharp remote (not a Universal remote)
Press MENU
Scroll left or right to SETUP
Scroll up or down to PICTURE FLIP
Scroll up or down to STANDARD
Press ENTER
Press MENU
That should turn your picture normal. Let us know if it worked.
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable. * Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet. * When it powers up you will see a little "k" appear in brackets. * Then on the TV, press and hold {VOL -} & {CH -} down and release. * The Service Menu will be displayed. * Use {CH+} {CH -} buttons to navigate * Use {VOL+} {VOL -} buttons to adjust the value. * Turn the set off to exit the Service Menu.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
1 Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
1 Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
