Question about Lowrance Boating
Lowrance elite 5 HDI cHart is not accurate. When I am at my dock the cursor shows I am in a cove about a mile away. I also don't know how to set the scale of the chart view.
  • Lowrance Master
  • 3,577 Answers
Its not the scale,, its the settings.. are you using a Navionics card or the built in map... there is a setting to tell the unit which one you are using.. the navionics card needs to be told what section of the USA you are in. Sometimes mine decides I am in North Georgia..(never been fishing there!?).. I have to set it back to sweet home Alabama.
Hope this helps..
Posted on Jun 13, 2017
SOURCE:
SOURCE: Excel Charts in PPT 2003 and 2007 not working correctly
Have you tried uninstalling the beta, and possibly uninstalling and reinstalling your copy of Office 2003?
Posted on Mar 25, 2009
SOURCE: How to draw 3D bar chart in Flash?
nbmhmnjmn,n,mm
Posted on Jun 18, 2009
  • 9 Answers
SOURCE: lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Posted on Jun 24, 2009
SOURCE: Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Press STOP/CANCEL to clear the display.
Posted on Jul 09, 2009
  • 43 Answers
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Posted on Oct 22, 2009
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
How do I set position on my lowrance hdi 7
The GPS will automatically triangulate your position and display it on the map screen.
If you have your cursor turned on the the map screen will remain centered on the cursor.
while on the map screen push the Menu key and then the Enter key. If you notice the pop up window when you push menu you will see the first field highlighted will be to return to current position or something similar. By pushing enter you are selecting this option and the unit will display your current position on the map screen.
Oct 17, 2014 | Lowrance Elite-7 HDI...
How do i do my updates for my elite7 hdi from my computer and getting them to my combo . my computer wont open the download through adobe.
Assuming you are using Navionics, plug your charts memory into your computer log into Navionics and follow the prompts for update
Oct 15, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
How to change language to enlish
Hi Kane,
I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf
Apr 25, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
How to wire a lowrance elite 7 hdi
Hi Everyone, Has anyone install EP-60R Fuel Sensor unit to Elite 7 HDI ? I have hustle making it work. Appreciate if anyone successfully solve similar problem. Dan
Jan 19, 2013 | Lowrance Boating
Boating Logo
125 people viewed this question
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
