Question about Panasonic Audio Players & Recorders
Hi I have a Panasonic sc-htb18 sound bar and a Panasonic tx-p50x60b tv I have no sound coming though sound bar via optical lead I've got my free view box via hdmi 2 and DVDs player via hdmi 1 thanks
  • Panasonic Master
  • 5,686 Answers
Optical leads have a red light that shows even when unplugged. If that is not on the socket is switched off.
Posted on Jun 12, 2017
Testimonial: "Hi the red light is on mate thanks"
  • 2 more comments
  • Mike Davies
    Mike Davies Jun 12, 2017
    i know that and it is on
  •  Grubhead
    Grubhead Jun 13, 2017
    It might be on, but are the sound settings correct for all your devices. Will they pass the signals to your Sound Bar? I assume the Sound Bar is connected to the TV via the optical. So is the TV's settings correct?
  • Gary Winterbottom
    Gary Winterbottom Jun 13, 2017
    Not sure I'll have to get instructions out mate
  • Gary Winterbottom
    Gary Winterbottom Jun 16, 2017
    Hi tv settings all good still no sound so changed optical to AV lead sound comes on but hisses like mad
    Master:
  • 612 Answers
If there is no sound from your player, you can check the following things:
1. Blu-ray player audio settings
2. HDMI cable connection error
3. Incompatibility between your Blu-ray player and TV
4. Blu-ray discs damage or restriction.
Posted on Jun 04, 2019
SOURCE:
SOURCE: HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Posted on Feb 13, 2008
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
dunnbiker
  • 8546 Answers
SOURCE: I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Posted on Mar 11, 2010
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Jan 05, 2017 | Panasonic Audio Players & Recorders
How do I connect a sound bar to my Panasonic TX-50A300B I want to use an optical cable as ear phone jack does not produce a decent level
If your TV has an optical port on the back, you simply get an optical cable long enough to connect the two. On your TV sound setup screen you'll have to select optical out so the sound from the TV will be switched from the RCA jacks to the optical out port.
Nov 21, 2015 | Panasonic Televison & Video
How do I connect a Panasonic TX-50A300B (TV) to a Panasonic SC-HTB20 Home Audio System?
The audio system sports both a HDMI input AND an Optical input - one can use either. The TV has both of those as outputs so you truly can use either!
You'll need a HDMI to HDMI cable or an Optical to optical TOSlink cable.
Feb 16, 2015 | Panasonic Audio Players & Recorders
How do I connect a Panasonic home theatre audio system sc-htb18 to a Panasonic tx-50a300b tv
Plug the red and white (right and left) RCA to the output of the TV and the other end to the input of the home theater. Then select the input on the home theater to match where you have it plugged into on the back.
Dec 29, 2014 | Panasonic Televison & Video
How do i connect my technics sh-dv290 to my tv and what leads do i need
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
Jan 02, 2013 | Technics SC-DV290 System
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
271 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
