Baby Gear Logo
d
deek Posted on Jun 08, 2017
Need 1 replacement pole for a ridgeway kelty ranier model 890110 part # 94 2014
Buenas noches compr? una casa de campa?a ridgeway by kelty modelo 89036 MEX pero no tiene instructivo ni varillas en donde podr?a conseguirlas gracias. Vivo en Guadalajara
Buenas Dia compa?eros.
Sugiera enviar un correo electr?nico a Kelty y pregunte si tienen varillas o un distribuidor en Guadalajara
https://www.kelty.com/contact-us/
Sugieren que pueden enviar a trav?s de gu?as de usuario de correo electr?nico para tiendas de campa?a m?s antiguas no estoy seguro de las varillas de reemplazo
Mi espa?ol es tan bueno como su ingl?s !
Have huge Kelty ridgeway tent, maybe 20 yrs old. Heavy metal poles labeled red, green, blue. Can’t find set up instructions. Help!
I believe I have the same Ridgeway tent - over 20 years old. Red-, Blue- and Green-labeled poles. Best setup will require at least 2 persons. Here is a quick guide to setup:
1. First, stake the tent floor down making sure it is taut.
2. Center poles are labeled with Blue dots. There are 3 separate poles that fit through the center channel - 1 straight pole with 'male' connectors on each end (this will be in the middle), and 2 poles with curved 'female' ends. The curved ends need to slip through the center loops (there's a 'hook' to hold the loop). The center upright poles consist of a bottom pole (which should have a cap on one end and an adjustable ring on the other) and a 2-piece snap pole (with grooves on one end). Make sure to slip the pole with the grooves through the adjust ring (this will allow adjusting the height of the center of the tent). There are also 2 strings at the center of the tent about a foot above the ground. Tie these strings around the upright center pole to ensure that the center upright pole doesn't separate too far from the tent.
3. Poles with Red dots are for the ends of the tent. There is a curved 2-piece snap pole that slips through the end channel. Then, you have a 3-piece straight snap pole that attaches to each side of the curved pole. The bottom end of the straight pole should be placed about a 1.5 feet from the bottom of the center pole (at about a 45-degree angle). The door ends are essentially 'leaning' outward from the center.
4. Poles with Green dots are for the extended door cover on the large door side. These are 2 snap poles with ends that fit through the grommet holes of the cover.
Photos of erected tent are attached.
We don't use our tent very often, but my son just took it camping and it was a breeze to set up. If you still have the plastic stakes, I would recommend replacing those with metal stakes, as the plastic stakes break easily. Also, you may need to find a rain fly that fits the tent.
Does anybody have instruction for Ridgeway by Kelty model 293719
Go to ehow.com.and search for ridgeway. You'll find it there.
I need replacement poles for old model melty tents
It is likely to be difficult to impossible. Expect that it might be fairly expensive. Contact Kelty at:
1-866-349-7225.
In Canada, email: [email protected] or call 1-866-349-7225 x 3726
Ridgeway kelty 890110
http://www.kelty.com/t-instructions.aspx
This page should have instructions for Kelty products, but the search function has neither "ridgeway" nor "elevation" so perhaps it is actually a different brand?
2helpful
Need assembly manual for Ridgeway by Kelty 89034 MOAB tent
Here is the Ridgeway Kelty Moab Tent (Style 89034) assembly instructions.
Need replacement poles for a Kelty Gunnison 2.1
If you are in Japan it might be a bit more complicated, but your first step is to email Kelty at [email protected] and explain what happened. They may send you anew pole, or tell you where to get one, or sell you one.
22 knot winds are nothing special, and most camping equipment should be just fine in those conditions.
Top Kelty Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
