GPS Logo
M
Margaret Chadwick Posted on Jun 08, 2017
On navigon what is the difference between red rout and green rout
I have navigon 6300 Gps when i switch it on it starts up then switches off
Hello
Check the power source. If the battery of the vehicle has not enough charge, this may happen. Check it. The problem is with its working voltage itsef. OK.
Jan 28, 2012 • Navigon GPS
1helpful
2answers
The gps sreen is disable and i cannot inter letter, number or touch the icon in the screen
My name is Mike, I am a GPS expert. A lot of your problem is updating issues, and rebooting issue. Please read all this information below. Thanks So Much, Here is some of my personal experiences, Sense I am also paid to test new units that hit the market through manufacturers.
Update: September 8, 2011: Navigon was taken over by Garmin. There are NO MORE USA MAP UPDATES for this unit. If you buy it you will NOT be able to update the USA maps.
I'm terrible with directions so I bought this hoping it would help me and it did. It found the satellites immediately and kept me moving along quickly. It updates quickly and even if you choose a different route it recalculates a new route and maps it out instantly. The touch screen is responsive and easy to use. It's well made and doesn't feel cheap. The windshield mount works easily and holds the unit in place.
When you register the unit at the Navigon website, you'll find out that a software update is not necessary as of today. FreshMaps is supposed to be available this month (July) and you can sign up for E-mail notification as to when they'll be ready for download. The unit comes with a 2 gig memory card and you can install a larger one when it's needed. The operating system for the mapping program is Windows CE. No problems with it yet.
So far, I'm happy with this unit. It does what I need without a load of unnecessary bells and whistles.
August 3, 2008: As of today, FreshMaps update is now available for this unit. Just go to the Navigon website, log into your account and download the Navigon downloader program. Install the program on your computer and you're ready to go. You can even backup your old maps with this downloader program which is recommended before you download the new maps and install them.
October 1, 2008: Navigon now gives you FREE lifetime traffic information. You just can't go wrong. I've been very happy with this unit.
HERE IS SOME MORE COMPUTER BORING INFORMATION TOO:
The Navigon models, like many competitors, use a customized version of Microsoft's Windows CE as their basic operating system - augmented by a software package which includes the Map information, Points Of Interest, and the manufacturer's particular 'twist' on a User Interface (what you deal with, onscreen, to enter information and use the device). The Navigon units use a 2GB SD Memory Card to hold it all - which allows for an easy hardware upgrade (pop in a bigger Card) if the data-handling needs ever grow beyond 2GB. (In comparison, my ancient Garmin had a 32MB internal chip, and wasn't expandable.)
BOTTOM LINE, IS YOU NEED TO TURN POWER OFF, AND AS YOU TURN IT ON, HOLD ON BUTTON ALL THE WAY THROUGH BOOT UP UNTIL IT TURNS COMPLETELY ON THEN RELEASE ON BUTTON. IF THIS MANUAL REBOOT PROCESS DOES NOT WORK, NEED TO UPDATE UNIT.
I HOPE THIS HELPS, MIKE, FROM FIXYA
also to contact me for future problems, check out my direct market place site through fixya for other areas I am a expert in. Thanks Again, Mike
http://beta.fixya.com/users/mc1bean
My Navigon 2100 GPS lights like it's charging, but it won't turn on
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
The styandard voice that comes with the Navigon 2100 is irritating I can tell there three voices, but I cannot change to one of the others
the different voices are for different types of voice prompts and at this time there is no way to change them around, got this from Navigon support site
How do I get a User Manual for my Navigon 2200T
No further help is needed. I found the manual at a different internet site.
2helpful
GPS 439 IGO route 66 -Car GPS can not find navigation not working
my navigon gps series 2100 has a problem with calculating the route and showing the turn - by - turn list.
Jun 18, 2009 • GPS
42helpful
9answers
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
13helpful
2answers
Navigon 5100 won't turn on when battery is charged.
try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
