Drills Logo
P
Philip Mygatt Posted on Jun 08, 2017
New lithium 40V Ryobi battery. When I put it in the charger all four green lights came on but never went of. Reinserted and the red light is steady but not charging battery, no green lights on battery
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 22, 2009
SOURCE: ryobi battery charger
The same thing happend to my charger, i let it cool down and now the green light goes off and shows red again. thanx for that post
Anonymous
  • 111 Answers
  • Posted on Mar 16, 2010
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
JOHN LAPIER
  • 2602 Answers
  • Posted on Jan 16, 2011
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Anonymous
  • 4 Answers
  • Posted on Nov 19, 2011
SOURCE: Makita 18v lithium battery when put on charge
This isn't true because I have a second charger and it works fine
speedw752
speed
  • Posted on Dec 12, 2012
SOURCE: ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
1helpful
I have two ryobi 40v batteries. One is brand new and they other is about two years old. The old one got the red green on the charger so I got a new battery. Got the same red green with the new battery....
Completely dead batteries may cause the charger to not see any load and it wont charge them. The way around this is to put the battery on the charger with the charger unplugged. Then plug in the charger and check the lights. Keep unplugging and plugging in the charger till it catches up and stays on.
2helpful
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the...
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
2helpful
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 • Drills
1helpful
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
13helpful
2answers
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Have a p103 battery that was in the p113 charger overnight and don't think it ever got out of the testing phase. The only difference was that the red light would flash about 5 or 6 times then stay on...
If you are sure your charger is working properly then your one battery may be shot.. i even had a new battery quit charging and had to replace it. they do not come cheap.
3helpful
2answers
Ryobi lithium batteries won't take charge
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
