SOURCE: how to open a ACER AL1713 monitor
Hi - there are more hidden screws so you need to undo those:
If your monitor is not working (even if the power light is dead), check for swollen electrolytic capacitors (tall things with an x at the top, made of metal with plastic around them). If you have swollen ones, that's probably why the monitor doesn't work. Replace them (make sure the + and - sides are in the correct places when you replace) and hopefully your monitor should work.
If it still doesn't work, look for any heat damage and poor soldering.
SOURCE: I can't open the case on a ACER AL1916B monitor,it
refortsm, you didn't say that you looked at any video clips on YOUTUBE that deal with LCD monitor disassembly. Find very , very DULL butter knife or table knife. You do not need a trip to the "ER" for a self-inflicted stab-wound!!! Some use old cd rom disc's for release of perimeter locking tabs???? Protect the units glass LCD panel at all times. You crack-it, then it's "You bought it you own it toyota!" "game over" for you. Removal of rear cover is hardest part of unit "tear-down" and inspection. Key for you is START at bottom with B-knife and pry gently. I hope this helps. Let me know about your "switch-mode-power-supply" condition. lmistyrel on aim. or 12fixlouie on Fixya
SOURCE: i am trying to open a samsung np r 60y laptop i
Check closer to the screen,under the keyboard,almost in the middle section
SOURCE: how do I open cover of Acer AL2021 Monitor ?
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom.
2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor.
3. Undo the screws and remove the bracket.
4. Under the bracket is the final screw.
5. Try pulling the front off the back starting at the bottom. It'll require a little force.
6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
SOURCE: i do't have driver for acer V193HQV lcd
YOU dont need drivers for a lcd screen, just lug it and it will work
