Question about Dell Computers & Internet
How can I play Disney's Dinosaur Activity Center when I open and install it on my Dell Windows XP Professional desktop?
    Sergeant:
  • Dell Expert
  • 445 Answers
It is a windows 98 game
Posted on Apr 24, 2019
SOURCE:
SOURCE: Control Panel Display Icon Won't open: Windows XP Professional
As circuitous a route as this may seem, try this:
-> Uninstall nView.
-> Reboot.
-> See if you can open your Display settings in the Control Panel, or by right-clicking your desktop.
---> If you can access it, you should be in the clear. Re-install nView if you'd like--although I personally have never seen a need for it.
---> If you still can't access it, reboot your machine, and keep mashing the F8 button on your keyboard. This should bring you to the boot menu. Boot into safe mode, and see if the Display settings will open.
---> If you couldn't access the Display settings in safe mode, and have access to your Windows installation media, insert it into your CD/DVD drive and reboot. Hopefully your BIOS settings know to check optical drives first in boot priority. Run the Windows Repair (or is it Recovery?) tool. See if this helps.
Best of luck!
Posted on Nov 09, 2007
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
Posted on Jan 06, 2009
cpenzes
  • 1102 Answers
SOURCE: Acer Aspire 5735z Install XP
okay you might want to write this down make sure you have your product key #
put winxp
into cd drive then restart press F7 during restart then choose option start with cd or cd/dvd whichever you have
then press enter follow instructions YOU DO NOT want to press F6 for third party or raid let system go past that
then when asked to setup on the chosen space CLICK TO DELETE partition ( or unpartion ) then enter will ask to confirm
once all confirmed your installation will start
let me know how it goes MAKE SURE YOU READ ALL THE INSTRUCTIONS THE SYSTEM WILL GIVE
Posted on Jan 26, 2009
  • 5 Answers
SOURCE: Windows XP will not detect disney mix max plus for initial charge
I had the same issue. I took it to a friend of mine who is good with computers hoping he might be able to fix it........and he did....apparently the HOLD button was slid to the right locking all functions...once he slid it to the left closest to the power button, it worked fine. Imagine my embarrassment...I hope this is all that is wrong with yours as well
SOURCE: how to convert Pooh Days of Hunny Activity Center Exersaucer
Ok take the legs off of the top part (white) just twist and the top part comes off; then twist the springs off. Now take the legs that you took off and slide them through the first hole of the bottom from the bottom not the top; do all three legs and you have a table.
You can pop off the toys the tigger and flower one you have to push the thing till you have a big enough for it to slide through.
The disney pooh car pops right off of the top part; then you just unscrew the car from it's bottom (2 screws) take it off the track and volia you have a car.
I bought mine from someone but with a little bit of imagination I figured it on my own. lol.
Posted on Aug 04, 2009
How can I make Disney's Dinosaur Activity Center compatible with my Windows XP Professional desktop?
If the software patch is not available from your game vendor then you have no recourse other than to install a compatible OS.
Jul 12, 2017 | Compatible Video Game Consoles & Games
How can I install DirectX on my Dell Windows XP Professional desktop computer?
Dell is available to help you on a wide array of topics. Whether your issue concerns technical Dial Our toll-free number +18002044427 get instant support for your query. Read More.. Dell Support Phone Number 1 800 204 4427
Jun 21, 2017 | Dell Computers & Internet
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How Can I boot my Dell Dimension 4700 to a windows XP SP1 Bootable installation disk, I've tried changing the boot sequence and everything:( It just won't work, I don't know where to begin with this...
are you saving the boot sequence? cuz thats all you do is what you have done. but you have to read the page and push the correct button to save this setting. and are you leaving the disk in the machine? leave it in and retry
Dec 15, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Open Questions:
Computers & Internet Logo
35 people viewed this question
Ekse
Clive
Clive
