I just bought a Mr Coffee model BVMC-SJX36. It brews coffee fine and all set ups work but when I brew coffee the warming plate never comes on to keep the coffee hot. What is the problem?
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
try going to Mr. Coffee and ask. All you need to do is clean the jet with a paper clip! yeeesh!!! <http://www.mrcoffee.com/service-%26-support/product-support/product-faqs/single-cup-%28brewers%29/bvmc-kg5/BVMC-KG5-faqs.html>
This is the correct operation for this type of coffeemaker. It uses the thermal carafe to keep the coffee warm after brewing, and doesn't use power to operate a warming plate
No in the BVMC-PSTX90 or 95 series. If this is your model, Is a good coffee maker. If you are NOT drinking your fresh brewed coffee withing 25 min. YOU DON'T WANT a warmer/burner. And the reason why, IT BURNS the coffee. You don't have this problem with the "thermal Carafe".
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
