What kind of antena do i need for a KLH 5100 receiver mitch
How to connect a subwoofer to a klh 5100
this unit has a sub output on the back to connect to a powered sub, or an amp/reciever and passive sub
Klh model 20 no volume
what kind of speakers do you have hooked up? make sure your cables from the speakers are good. you should have an RCA type hookup on your record player, make sure they are in there good too
STATUS OF MY ORDER?KLH R5100 AUDIO VIDEO RECEIVER?
Sorry. I haven't the user manual for KLH 5100 audio video receiver with me now.
I DON'T KNOW ALL FEATURES AND CONNECTIONS FOR MY KLH R5100 AUDIO VIDEO RECEIVER.I NEED A MANUAL FOR MY RECEIVER.
I don't have the manual with me. I found KLH R 5100 with user manual in the following link. Tray to contact them.
OK
http://www.ebay.com/itm/KLH-R-5100-Receiver-Hi-Power-/250902259353
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Need to set channels no remote
can you get in the menu screen with the built in buttons on the TV? if yes then go to menu, go to tuner, select antena or cable, and scan.
Broken volume knob
I located the remote control for the unit and it works fine. As the unit is not the primary amplifier for the home stereo system, I use the remote to control the volume. Thank you for your quick responce, and I will keep you in mind for any future needs.
George Keeler
1helpful
Klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
