SOURCE: Car parts
Well.....It is not Close to you By any Means But, This is where I get my Parts for Fords and they will ship them to you, If they do not have it they will find it! Bob Howard Auto, serving Oklahoma City with a large inventor...
Bob Howard Auto is an Oklahoma City New and Used Car Dealer offering Sales, Service and Parts for many makes, including Ford, Toyota, Honda, Chevrolet, ...
www.bobhowardauto.com/ - 18k - Similar pages
http://www.bobhowardauto.com/
SOURCE: wanting front loader door repaired.
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web but not supplying engineers or spares ;-0)
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
SOURCE: Rear Projection Toshiba sticker on side of TV
Good day!!!
That problem could be on the power supply...
if
the power supply output is having voltage drop the problem could be the
capacitors...some bad capacitors have bulged on the top and bottom.some
are not!!!
try to look at the power supply board if have
leak/bulged on the top that is better..just replaced it with the same
type,ratings and value..
also try to re-solder the power supply board before you go to the major troubleshoot..
if the problem persist just add a comment..
If
you think the power supply is impossible to repair don't worry the
whole power supply is available on the market so you can order it..but
before do that try to repair it on your own just keep in touch to
fixya..and I will do my best to help you..
http://www.thermadyne.com/IM_Uploads/DocLib_1498_43-59.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_1673_CIGWEL56.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_4168_0-4949.pdf
http://www.thermadyne.com/IM_Uploads/DocLib_4143_0-5072.pdf
If your gun end is a Tweco, those are pretty much standard and readily available from welding supply houses. If the retainer for holding the liner is broken you would get that through Thermadyne.
