Remove the flat rubber platen cover to expose the lock ring at center (horseshoe clip) remove this lock ring and pull the platen straight up and off , under there you should find a rubber tire and the drive motor shaft , turn unit on , you should see motor turn and then it should move rubber tire , if not , your going to need to replace it or clean it up and lube it
