Question about Broderbund PrintMaster Platinum Version 18
How to configure Printmaster 12
"Cannot determine configuration" pops up when I try to click on my Printmaster 12. What does this mean and how can I fix it? It has worked fine for years, but I recently had a virus and had to have it cleaned... might this be the problem?
  • 32 Answers
Melodie roba,
Most definitely this could be your problem! I would reccomend that you completely uninstall Printmaster 12, run another virus check, then reinstall the program. Once the program is installed, update it through the vendor and it should work fine. You should be able to find the vendor (PrintMaster) updates through the help menus.
Hope this helps,
-samson39
Posted on Jul 26, 2009
SOURCE:
I have 3 12in kickercvr 2oms dvc trying to keep it at 2oms
Using 3 of the sub woofers you mention will give you a load of 0.36 OHM in Parallel/Parallel configuration, 1.67 OHM in Series/Parallel configuration and 12 OHM in Series/Series configuration. To get a 2 OHM load for you amplifier, use only 2 of the sub woofers and connect them in Series/Parallel configuration. If you don't know what this all means, let me know and ill explain it to you.
dreamsystems
Feb 12, 2011 | Car Audio & Video
I cannot turn on wireless capabilty using fn and wireless symbol. Is there any other way of turning wireless capability on?
Follow these Steps :
1> Go to start
2> Click on RUN
3> Type SERVICES.MSC
4> New Window will appear
5> Go to bottom of the page
6> Select Windows ZERO Configuration
7> If it shows Manual then Right click on this service
8> Go to properties
9> You will get START TAB
10> Click on START
11> Click APPLY and then OK
12 > Select AUTOMATIC where its shows start service MANUAL
Now try to connect with wireless connection
If still its not working then folow these steps .
1> Go to Control Panel
2>Click on Network Connections
3>Right click on Wireless network Connections
4> Click on properties
5>New Window will pop up
6> Select Wireless networks tab
7>Check very first option which says " Use Windows to configure my Wireless Settings
8> click on Apply
9> click OK
now try to connect with wireless
Apr 29, 2010 | MSI GX630-028US Notebook
Window xp;and printmaster gold 16; printmaster will not download fully, when i click on the printmaster icon it has pop up that has windows has configures with windows ask for the install disk, then after...
Was this download from a P2P site? Sounds very suspicious
This is a Commercial program and is usually not freeware as I can gather.
If you downloaded it from a non-reputable source, you more than likely have received some form of malware.
I would recommend deleting it and running a full system security check.
It's only about $7.00 from a secure provider.
Regards
Dec 06, 2009 | Microsoft Windows XP Home Edition
Windows wants to configurate certain programs every time l open them
If you see the pop up "Please wait while windows configures..." when you open an application, it means that an important module of the program is damaged or missing. First determine the application that this is happening with, and then completely uninstall/reinstall the program. If it continues to happen, you will need to have a professional look at the installation.
I offer remote control assistance too! - www.LoganComputersER.com
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
I recently had my computer serviced for a major virus attack. System operates on Windows XP. I now cannot open PrintMaster Platinum 12. I get a message "cannot determine configuration." Additionally, I...
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
Nov 06, 2009 | Broderbund PrintMaster Platinum 15 Full...
Can't install printmastersilver12 ''cannot determing configuration
where is there main website or what are the requirements for this application - was it designed for windows 98 or what exactly ??
Apr 18, 2009 | Broderbund Printmaster Silver 12.0
I have a error message when trying to open printmaster platinum 12
Use window search find the file and delete I did what was at support and it did not work I found this file in all users folder deleted it and all is well
Sep 05, 2008 | Computers & Internet
Broderbund PrintMaster Platinum Version 18 Logo
1,213 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
