For a long time now it has only charged one side. I want to try to fix it vs. buying a replacement. When I put the Wii remote in the charger a blue light typically shows until it is fully charged then the light shows green. Now, no light whatsoever. I know its receiving power because the green light flashes when it is plugged in as I mentioned. Does anyone have an idea as to how to fix it?
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
SOURCE: Power on Board 450 portable charger light - green flashing
What your seeing there is indicating fully charged.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Testimonial: "Thanks - that was what I was hoping for!"
