I've had this mouse for a few months, so, knowing it took batteries, I changed it out yesterday, and it did nothing. Trying the connect button that plugs in to the usb port with the new battery in, the usb flashes the green light, and than pressing the connect button on the mouse itself, nothing happens. I've took the battery out at least 3 times, looking inside where the battery goes, it looks ok, nothings out of place. Plugging the usb port in, pressing connect, and than on the mouse again, still, nothing happens. Any one have an ideas or can solve this for me, I'd greatly apperciate it!.
Nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
