Computers & Internet Logo
S
Sandra Parrott Posted on Jun 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unlock my dell laptop keyboard - Dell Computers & Internet
wd neojoneswd
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on Jan 29, 2019
wd neojoneswd
Expert
Level 2:
Novelist:
Answers
222
Questions
Helped
29245
Points
300
How did it get locked in the first place?
How can I unlock padlock with 9 in middle?
Karen Crain,
The padlock with the number 9 turns on when the numeric keyboard is enabled.Click the numlock key on the keyboard and it should go off.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
How to unlock keyboard for dell isperon 7000
There is no way to lock, or unlock the keyboard. Please try booting your system, and press F2 and see if you can enter the BIOS. Try this with the internal keyboard. If this does not work, then try running the keyboard test from the Dell Diagnostics. The internal keyboard should work, even when an external keyboard is attached. See if the keyboard will work in the diagnostics. If not then you have a keyboard failure
2answers
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    2helpful
    The keyboard is locked
    Dear Sir,
    plz folow this step to unlock keyboard
    1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
      For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
    5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
    6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Thanks For Your Time,
    9helpful
    Dell keyboard locked up
    Dear Sir,
    PLzz folow this step to unlock your keyboard
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    How do i unlock my dell laptop keyboard?
    ring dell and they will do it for free providing you are the registered owner and can prove it
    I am unable to unlock my laptop keyboard. Please Help!!
    So you need to regain access to your Dell Laptop?
    Try the following Link,
    http://www.ultimatebootcd.com/
    Download and create the disc.
    That should do the trick!
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
