Popup Blocker Pro
This is a good app for Chrome browser (if you use this browser) How to Block Pop Up Windows in Safari
The above link is for Safari, (it is a little bit complicated for Safari but not impossible)
SOURCE: to eliminate popup AOL's SpyZapper No Longer Available
AOL FINALLY listed the way to remove this major annoyance.
And it actually WORKS.
Delete the SpyZapper components manually.
Log in to your computer using the administrator username and password, and then search and delete the following files:
Note: Generally these files are located as below:
AOLszs.drv & settings.ini files location:
OptScan.exe file location:
SOURCE: popup GOEC62 DLL
Hi there.
I understand is with google taskbar or desktop utility.
The best thing to do is uninstall google apps and then reinstall them.
Good luck and thanks for choosing FixYa!!
SOURCE: Charger Error Pop Ups
dear,
this issue directly related with the charging circuitry... the issue
can either be with the charger itself or majorly with the charging ic
i had faced this problem with the chinese mobile phone but this can be
either with the chinese model or can be with the other...so check the
both things one by one...hopefully the issue will be resolved..
regards,
dont forget to rate this if issue resolves.....
SOURCE: Menu pop ups
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
SOURCE: Acer eNet Management
Do you have "What do you suggest I do to stop the alternating messages? It's almost as annoying as popups." I get an alternating popup (actually fade in fade out) message. the alternating message says "Acer eNet Management Internet Disconnected" Here is my solution!!! :)
First 'Right-click on task bar', TASK BAR IS AT THE BOTTOM OF YOUR SCREEN' then click on 'Properties'. Click on 'Notification Area', Click on 'Customize', Look for WLAN(disconnected), Click on it and choose 'HIDE', Click 'OK', then click 'APPLY', then click 'OK' and now you have no more annoying message. TOO EASY MATE ;)
