I hate dryers but inherited this one with the house we bought as it is integral
SOURCE: hotpoint ultima washer dryer
ok lay the machine on its side the side with the soap draw under you will find the outlet pipe runing to the pump then another hose going from the pump to the bottom of the drum. if you disconnect the hose from the bottom of the drum you will find the filter remove this hose from the other end and clean the filter and hose with hot water once replaced check the hose in tight it may be tricky to replace stand up the machine and test using water only and an empty drum.
SOURCE: hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
SOURCE: Hi. We have a hotpoint washer dryer aquarius wd64
REMEMBER: when checking the resistance ensure that all wiring is disconnected from testing points!
Remove the top cover of the washing machine, you'll see about a foot size aluminum casing of the heater itself. Using a multimeter set on resistance (ohms) check the resistance between two welded pins (heating element) The readings should be roughly fom 0 to 26 ohms. If there's no readings you'll need to replace heating element, othervise check the resistance of thermo-fuse wich is located between those two welded heater pins. one of the wires connects heating element and thermo-fuse directly. The readings should be around 0 ohms, if no reading just replace the thermo-fuse.
Lets end at this point for now, as replacements thermo fuse solves the problem in most cases.
Please update me about your success, If unfortunately it didn't helped, just say and we'll find the solution!
Good luck
SOURCE: just moved home, hotpoint BHWD129 washer/dryer
Here is a link to the manual for your washer/dryer.
http://laundry.manualsonline.com/manuals/mfg/hotpoint/bhwd129.html
SOURCE: Hello, I bought an Hotpoint
Because the units are combined the dryer has a built in a condenser dryer which should have a water retaining tank and if not emptied regular it can stink like ****. You need to empty the tank. Your model should pump the moisure out but has a reserve tank.
