My washer has started to not work in final spin and it is not draining the water out of the washer or clothes what can I do to fix this problem
Hi
If the washer is not draining then it is due to a clogged
drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect
if the drain hose is plugged. Also check the connection to the drain pump and
make sure wiring is fine. Check the electrical connections with a multimeter.
If it still doesn't work then you would need to replace the drain pump. Hope
this helps...please post back for further assistance.
Daniel
