A service manual with diagrams would work for a stihl FS45
Hi try here hope it helps https://www.scribd.com/doc/190134377/FS45-Service-Manual
SOURCE: i can not cranck up my trimmer Stihl FS45.Has a
has it got compression? does it have spark to? need to check b4 go further....
SOURCE: A spring came off my stihl fs45 trimmer when I
This model is the closest this site comes to the model you have. it should help as diagrams should be in the manual on later pages. You will need Adobe Acrobat Reader as the manuals are in PDF form:
http://lawnandgarden.manualsonline.com/manuals/mfg/stihl/fs_55.html
Please vote on this solution.
SOURCE: The head fell off my Stihl fs45 string trimmer and
unless you were misusing the trimmer it is under warranty... if you are the original owner there is a lifetime warranty on drive shafts and cables
SOURCE: I have a Stihl FS45
http://stihldealer.net/videolibrary/OnePlayer.aspx?v=27&vt=27&vb=2&id=27
There 3 types of heads that your trimmer should have. The issue is most likely related to how the line is wound on the spool. Click the video link for detailed instructions for your Stihl trimmer.
SOURCE: schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
