You can unlock your samsung mobile by two diffrent method in one method you can unlock your samsung mobile without unlock code
Samsung unlock without code
and in second method you generate unlock code from imei number of your samsung mobile. It generate 4 kind of unlock codes.
http://mobile-cellphones.blogspot.com/2016/03/samsung-mobile-sim-network-unlock-pin.html
I suggest you can approach Prounlocking.com and specify the country,locked network of Samsung .Based on the availability you can get the permanent unlock service along with free instructions.
SOURCE: samsung SGH-x475 t-mobile unlock code
sure the unlock code goes as follows... *2767*6903557610011172#
after you do that it will seem to shutoff but leave it and it will then open up to working screen... you will have to enter this code each time you turn off the phone but it should work,,, if u have any questions... e-mail me at [email protected]
SOURCE: i need the network unlock code for samsung SGH -E390
To unlock your samsung mobile,follows these steps
Do a custom reset:
*2767*2878# once this has finished rebooting turn the phone off.
Next
a SIM card from a different service provider needs to be pushed half in
- (Push it fully in then slide it back out by about 1/2 a centimeter),
Turn on the phone - you will now see an "Insert SIM" message,
Now perform a full reset:
*2767*3855#
When the phone powers off, quickly push the SIM card fully in, and let
the phone power back up.
After you do the reset, check and make sure that your Network lock is active by pressing *#7465625#
If it isn't active you must use this code to reactivate it:
*7465625*638*00000000*00000000#
Then you have to deactivate the SP lock first. To do that you need to input:
*7465625*77*00000000*00000000# (this will reset the lock)
Then you enter:
#7465625*77*00000000# (to disable the SP lock).
Then you disable the Network lock:
#7465625*638*00000000#
The phone is finally unlocked.
SOURCE: what is the unlock code for samsung sgh-a237?
Hai,
You visit this website mobileunlockguide
In that site U can get the unlocking instructions and the unlock codes for Your mobile.
SOURCE: I need remote code to unlock Samsung Blackjack SGH-I607
FIRST REMOVE THE BATTERY AND THEN SIM CARD.
PLACE BATTERY BACK IN AND THEN TURN PHONE ON.
NOW PRESS: #7465625*638*75297038# (THIS WILL BRING UP NUK BOX)(NETWORK UNLOCK KEY)
THEN PRESS IN: 75297038
IF DONE CORRECTLY IT WILL SAY SYSTEM UNLOCKED.
NOW PLACE ANY SIM FROM ANY CARRIER AND ENJOY....
IF THIS WAS SUCCESSFUL, PLEASE REPLY BACK WITH A SIMPLE THANKS....
