Watches Logo
A
Allan Ong Posted on Jun 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The second hand of my charriol watch suddenly moves 5 seconds for every tick. Does this mean the battery is wearing out. Thanks.
Level 3:
  • Charriol Master 18,429 Answers
  • Posted on Jun 01, 2017
Charriol Master
Level 3:
Answers
18429
Questions
Helped
1404870
Points
62248
Yes your correct you need new battery
Instruction manual
If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
4helpful
Second hand is moving at 4 sec incremants not second by second
This is low battery warning. Replace the battery and the watch will tick as new.
Rate me, please
5helpful
Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
12helpful
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
23helpful
Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
www.finewatchmaking.com
1helpful
Second Hand
it is the battery life indicater get the battery replaced it will fix the problem
Top Charriol Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Charriol Watch Expert? Answer questions, earn points and help others
