First, you should keep away from the T-160 tapes as they are thinner and more likely to jam. The T-120 or less sizes are better. Next, use high quality name brand tape - not the off-brands found in the bargain bin.
Do the regular maintenance. All tape is "dirty" (including cassette, 8 track, reel to reel, etc.) and will deposit dirt on the tape heads and "transport" mechanism. Transport consists of capstan and pinch rollers that push / pull the tape in and out of the housing. when dirty, they slip and interfere with the "pick up" of a quality picture from the tape. Use of a quality wet cleaning system at regular intervals (or whenever picture quality deteriorates or tapes jam) is highly recommended. Here are some googled results for wet VHS cleaning systems:
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
You can get a cassette adaptor that will except any VHS-C tapes and play them back on any standard VCR from Maplin www.maplin.co.uk.
They are £14.99 plus post! It's unlikely that you just have to have the Panasonic one!
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
can u play the tapes live from cam use a video caputer card on pc record them live as u play as avi clips then u can save them all on dvd movies using nero 7 vison
hai,
If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
